jamie1.8tpologti
Posts: 139 Joined: Tue Sep 09, 2008 6:33 pm
Post
by jamie1.8tpologti » Sun Dec 14, 2008 3:46 pm
does anyone know why my jet washers are s**t? i put new pump on, new jets and it still dont work properly. doesnt even spray. anyone had similar thing happen? or know how to fix it? cheers
Bepe
Posts: 1575 Joined: Wed Sep 06, 2006 11:12 am
Post
by Bepe » Sun Dec 14, 2008 4:06 pm
all the power is in your engine mate so it is saying f**k everything else, dont need no washers! lol
Posts: 14874 Joined: Sat Nov 11, 2006 5:29 pm
Post
by alexperkins » Sun Dec 14, 2008 4:18 pm
Windscreen washers or headlight washers?
Bepe
Post
by Bepe » Sun Dec 14, 2008 4:26 pm
iam presuming he means windscreen alex, but wit would affect both if it was pump!
tegwin
Posts: 945 Joined: Mon Nov 13, 2006 5:14 pm
Post
by tegwin » Sun Dec 14, 2008 5:48 pm
Does the pump run when you push the button?
If so...
Then remove the sound proofing on the underside of the bonnet and check the hoses from the pump to the jets... I bet one of them is fuggered
jamie1.8tpologti
Post
by jamie1.8tpologti » Mon Dec 15, 2008 2:28 pm
i tried that but still cant see anythin wrong. ill ave to try new one
Mouse_GTI
Posts: 2937 Joined: Sat Apr 01, 2006 10:29 am
Post
by Mouse_GTI » Mon Dec 15, 2008 8:50 pm
Slight hi-jack...my so called heated washer jets are useless in this cold weather, even with the rear window heater switch on
tegwin
Post
by tegwin » Mon Dec 15, 2008 10:42 pm
Same here mouse....
Sadly... Even with heated washer jets.... the pipes still freeze....
Takes mine just under an hour to thaw out...
So I can drive to work, down the motorway with no washers...and then give the screen a nice wash off as I pull into the carpark at work....
Post
by alexperkins » Mon Dec 15, 2008 10:44 pm
They are very tricky to get working. The fuses for them often blow, and it requires a certain minimum of screenwash antifreeze for them to unthaw lol.
Luckily I have two new ones which work wonderfully
_dubstar
Posts: 111 Joined: Sat Aug 02, 2008 11:11 am
Post
by _dubstar » Wed Dec 17, 2008 12:40 pm
This is a common problem on all VW'S, You need to use good addative all year round or the jets furr up and stop workin correctly, I use genuine vw screenwash all year round since i replaced mine 3 years ago they still workin perfectly now. As for the heatin this is the same, they dont work very well if tryin to heat up limescale in the jet its self.
