cold air feed
Polo96CL
Post by Polo96CL »
BMC CDA with 70mm Cold air feed running behind the grill and existing pipeing for manifold.
Polo96CL
Post by Polo96CL »
I'll have to get you one. Be wary though you may have trouble getting the BMC to fit as the bonnet sits very low on a mk4. To get it to fit you will have to trim down the Silicone 90 degree bend so that its very short on the entry to the engine. You don't want to have a nice dent outwards from the bonnet when you close it! Also you need a breather filter from the throttle hose and the cold air feed to go into an area towards the front of the cars grill.
