How to I change the Direction indicator light bulbs
sanjivsai
Post by sanjivsai »
Dear Users,
I have a 2002 Polo and need to change the direction indicator bulbs in the rear of the vehicle - How do do this ?
Any help will be appreciated.
Regards
Sanj
randomage
Post by randomage »
I think you're posting in the wrong section mate, if memory serves correctly, you have a 9n. Try posting in that section, you may get a bigger response.
LeMeph
Post by LeMeph »
isnt a 2002 a 6N2?
either way its all pretty universal with nearly any car!
When you into the boot Sanj look around the sides for a way to pull the lining back. When you do you will see the rear side of the lights. Take a careful look at them and you should see how they are clipped in. Just unclip them pull them out and hey presto there are your bulbs! If you dont know which is which then turn all the lights you can think off on and work it out via process of elimination!
randomage
Post by randomage »
I wasn sure if they started making 9n 02 or 03, i could be wrong! :D
