Air intake
jezza
Location: Yeovil, Somerset & Essex Drives 1.6 6N polo and a G40.
Air intake
Post by jezza »
Im in the process of going back to my standard air box filter and changing the filter to a decent one. Only thing i need some help on is, do i keep the cold air feed and connect it straight up to the air box or do i put back on the section, that has the cold air feed and hot air feed, going into it with the sensor inside? I was thinking of connecting up my cold air feed to the sensor part so that im not using the standard one. Any ideas? Cheers.
Tim_GTi
Post Whore
Re: Air intake
Post by Tim_GTi »
It's up to you mate, try out both and see which you find best. I'd probably go with the OEM one though, as your putting the OEM box back on.
