happy new year everyone
Do you need different spacers for the front and rear of the gti? thanks
Spacers
- ticki
- Sponsor
Re: Spacers
anyone on here got spacers???
Redline
- Sponsor
- Drives: BMW 128ti
Re: Spacers
How do you mean by different?
The front and rear axles are the same 4x100 PCD size with a 57.1 centrebore.
Or do you mean whether people tend to run 10mm spacers on the front, 15mm spacers on the rear for example?
- ticki
- Sponsor
Re: Spacers
While they fit perfectly on the front hub, but because the centre hub on the rear sticks out more (approx 10mm). the spacer does not sit flush against the wheel face???
The spacer inside is only bored to a certain depth perfect for the front. but not the rear.
the spacer in question is very similar to the pic below
- ticki
- Sponsor
Re: Spacers
anyone please???
- Tim_GTi
- Post Whore
Re: Spacers
Do you have these spacers now Ticki? Or are you asking about a possible purchase?
My FK spacers fit fine on both front and back, and they are the same.
Re: Spacers
What size of spacers have you got tim?
- ticki
- Sponsor
Re: Spacers
i have them,
My bro had a 6n which they didnt fit either. He gave them to me to try out before i bought something aluminium,
they are steel hubcentric Delta Mic's 15mm part:7949
- Tim_GTi
- Post Whore
Re: Spacers
Mine are FK 25mm adaptors, so not spacers so to speak. they're hubcentric also, I bought them second hand so don't know the full spec of them. I can check the box next time I'm home though to see if that helps.
- ticki
- Sponsor
Re: Spacers
thanksTim_GTi wrote:Mine are FK 25mm adaptors, so not spacers so to speak. they're hubcentric also, I bought them second hand so don't know the full spec of them. I can check the box next time I'm home though to see if that helps.
