STARTING PROBLEMS ON A POLO 6N - Y REG
jas2009
Post by jas2009 »
Hi All
I have a starting problem with my polo. It runs fine BUT ocassionally when you turn the key it will just tick over and nothing will happen. You have to keep the key turned for around 30 seconds whilst its still ticking and eventually the car starts. I am not sure what the problem is.
I had the AA come out and they said its a lamda sensor. This is the fault that came up on thier computer.
I had a mechanic say that there is a electrical fault with the ignition!!!
Do you think it can be this or is there anything else?
vw-po-low
Re: STARTING PROBLEMS ON A POLO 6N - Y REG
Post by vw-po-low »
Sounds like an ignition switch. Drop it by either vw or a recommended garage and tell them the problem and what you suspect it is. Also get the lambda checked while there.
