[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 head swop - UK-POLOS.NET - THE VW Polo Forum
16v head no, you'll have to swap the engine, but you can put the 1.6 8v AEE heads on the 1.4 8v engines. Should give you some more torque andd lower compression ratios incase you want to turbo
