Headlight Switch Mod
mwbpsx
Post by mwbpsx »
has anyone got the how to guide to modify the headlight switch to enable fog lights without side lights??
i can remember u have to remove a pin or summatt ??? :?
mwbpsx
Re: Headlight Switch Mod
Post by mwbpsx »
40 views and no replies :?
nobody know or is it a secret :wink:
Well, I was one that looked and thought WTF? I still think that I am of that opinion, have I missed something - VAG and others have put a lot of thought into what could be doen to avoid plonkers driving around with annoying foglights on when they are not needed - and the law takes that same view - so why are you trying to be different - I'm just curious, that's all! Personally I think that it might be a good idea to also use these front fogs as day time driving lights, but the EU rules wisely require you to have the front fogs, or headlights on if you don't have front fogs, before switching the rear fogs on.
ihpj
Post by ihpj »
RUM4MO wrote:Well, I was one that looked and thought WTF? I still think that I am of that opinion, have I missed something - VAG and others have put a lot of thought into what could be doen to avoid plonkers driving around with annoying foglights on when they are not needed - and the law takes that same view - so why are you trying to be different - I'm just curious, that's all! Personally I think that it might be a good idea to also use these front fogs as day time driving lights, but the EU rules wisely require you to have the front fogs, or headlights on if you don't have front fogs, before switching the rear fogs on.
Well said that man! Please don't drive with your fogs on when not needed - it is irritating, annoying and causes frustration to other road users.
mwbpsx
Post by mwbpsx »
according to my handbook they are called driving lamps and i wish to use them when driving, the police tried to prosecute others and failed because of this so what is ur problem ????
mwbpsx
Post by mwbpsx »
further to my explaination of the law i will add that as i have upgraded my sidelights to leds they are bright enough to illuminate any fog or mist that arises where i live in mountanous north wales. i dont live in a city, its coastal and rural and we get fog, mist on a daily basis
i want my fogs/driving lamps on without sides so that i can drive safely and if that annoys you tuff titty.
the amount of cocks who put main beam on in fog still amazes me maybe thats my problem as in ooooh i want to see a white wall ????
i drive on side lights so as not to annoy people in single story cottages who are in bed when i drive past
if i lived in a city that had street lamps i wouldnt need lights at all but thats a different story
but unless u want to walk a mile in my shoes pull ur neck in and get a grip on the difference of weather conditions in our nation that might actually neccesitate (apologies for spelling if wrong) fogs or driving lamps to be used independantly of other lights
mwbpsx
Post by mwbpsx »
i eagerly await the responses or apologies
mwbpsx
Post by mwbpsx »
btw to me a plonker is one who makes a statement without knowing the full facts...............ie making a plonker of oneself
mwbpsx
Post by mwbpsx »
this ignorance reminds me of the statement that a man should never ever ever hit a woman
until she comes at you with a chain saw
ignorance is bliss
An awful lot of postings by you on this subject, strange! I live up North and we also get lots of mist/fog rain - and I live well above sea level. Taking a few of the points that you have mentioned - you need to drive without side lights - why, is it because you have swopped out the miserable little bulbs and fitted LED clusters with many nasty points of bright light - this light output will be uncontrolled wrt distribution so their only purpose will be to act as markers - but in a better way than the original little bulbs did - while annoying other road users under normal conditions and it seems causing you problems with scatter off the wall of fog/mist, something that the original bulbs woulkd not. Maybe you should just give up on the LED cluster and revert back to miserable bulbs until EU legislation mandates that we need to run with "running" lights and so these "side" lights can revert to being "parking" marker lights.
SimonCorrigan
Post by SimonCorrigan »
mwbpsx
Post by mwbpsx »
first sentence from your posted link 'fogsoff.com'
Fog lights are for.... fog!
There is a clue in the words:
"Fog Lights"
in that case what are 'driving lamps' for ??????
is there a clue there i wonder
SimonCorrigan
argue it with plod when they pull you over as you seem to be well versed in the law.
mwbpsx
Post by mwbpsx »
ok to put an end to this:
i do not intend to drive using driving lamps as a norm, read my earlier posts.
the offence you would be charged with is 'improper use of lights'
it is a fine and no points
you turn over the fixed penalty notice and write: I wasnt using my lights improperly
you wont even get a reply!!!
this is fact my son had the very ticket
2 yrs ago and still no reply
Si_GTi
Moderator
Post by Si_GTi »
mwbpsx wrote:40 views and no replies :?
mwbpsx wrote:i eagerly await the responses or apologies
mwbpsx wrote:this ignorance reminds me of the statement that a man should never ever ever hit a woman
mwbpsx wrote:ignorance is bliss
Give it chance!! Not everyone is in front of their keyboards and waiting for new posts to reply to. If you relax and allow a little time for other forum users to respond you will get the info or advice you need.
