I am trying to install some LED strobe lights behind my front grille.
I have removed the front VW badge, and there is a clip on the bottom part of the grille which is easy to unclip (at the botton of the VW badge).
BUT I can't remove the top of it...
How do uI remove it?
And also, is there a place to feed the wires through from the bonnet to the centre console inside the care.
Thanks.
(Sorry didn't mean to post in the Mk3 forum, it is a Mk4 lol.)
!! How to remove front grille? HELP!!!
- bananaskin
Re: !! How to remove front grille? HELP!!!
Is it a factory fitted grill?
replaced my grill 2 days ago....theres 4 clips at the top which if u use a knife to press down thenb push the top of the knife towards the windscreen should be no problem altho one of mines was rusted so a part poped out, on mine was also 2 other big plastic clips/catches at the bottom left and right, hope this helps!
Yeah.bananaskin wrote:Is it a factory fitted grill?
- bananaskin
Exactly the same kyle_mk3
ohhh n dnt be 2 rough as the body work either side of the grill moves
