Removing front badge
sagaris
Post by sagaris »
I want to remove my front badges, I know there's some screws on top of the grill, but where can you get the tool to remove it or what can I use?
chewy
Re: Removing front badge
Post by chewy »
To remove the front badge mate give it half a turn (cant remember which way) then it should pull out. Just be careful as the plastic clips can break if you pull hard on it
If you want to remove the grill its a torx bit you need T20 iirc
Like these :D
sagaris
Post by sagaris »
Apart from the 4 screws at the top is there anymore I need for removing the grill.
Cam 9n3
Post by Cam 9n3 »
Therte is 4 clips along the bottom of the grille....stick a screw driver threw and lift them up n the grille should slide out! :D
