PLEASE HELP
braindeadhmster
PLEASE HELP
Post by braindeadhmster »
I`m trying to fit this kit, Rightclick AL60B-PLUS
I`ve connected everything else except r/c/l. Below is the instalation page.
https://www.rclick.co.uk/information.php?info_id=13
Can any body tell me where to connect what to what?
Re: PLEASE HELP
remote central locking ye?
http://lx-designs.net/personal/vw_polo.pdf
If thats what you are asking, that should help.
braindeadhmster
Re: PLEASE HELP
Exactly wat i needed. Thanks alot.
How do i increase the pulse to 3 seconds?
Re: PLEASE HELP
for the CL pump run?
braindeadhmster
Re: PLEASE HELP
Yeah apparently i need to increase the length my main unit sends the signal for. From v0.5 to 3 seconds.
Re: PLEASE HELP
Should be some jumpers on the main control box for the CL - have a look round the edges. if not, take the lid of it and look 0.5 and 3 writing on the circuit.
braindeadhmster
Re: PLEASE HELP
Had a look cant find anything. What do jumper look like
braindeadhmster
Re: PLEASE HELP
Found jumpers but diagrams are the same. So dont know how to connect jumper so it does 3.5 output.
Re: PLEASE HELP
Should just be a case of moving it to the next notch?
braindeadhmster
Re: PLEASE HELP
I have. It makes no difference. manual says I need to connect wire to c/l main line, it says it`ll be (green/blue -main line). (brown -negative line) (red/blue - positive line). I cant find these wires on my box in the boot.
Re: PLEASE HELP
theres definitely a brown on the box in the boot - thats the earth wire.
As for open an close, its white/green for open and white/yellow for close (on the cars loom)
These wires are on the plug that goes into the central locking system, but it really depends which end you are connecting this up.Pedal side or boot side?
Polos dont have a positive negative trigger system...its a pneumatic one.
Im guessing you understand how wiring works with white green being a white wire with a green line, or dashed green stripes?
braindeadhmster
Re: PLEASE HELP
I`m trying to connect the door switch, the book says blue - positive door trigger and purple - negative door trigger. What color are the wires i connect them to on my car.
Re: PLEASE HELP
Are you referring to the door light switch so it knows when the doors are open?
braindeadhmster
Re: PLEASE HELP
Yah thats the one. Cheers mate
Re: PLEASE HELP
Should be positive trigger (blue) connect to brown/white behind the trim panel next to the bonnet pull
