Wheel spacing/bolts
jezza
Location: Yeovil, Somerset & Essex Drives 1.6 6N polo and a G40.
Wheel spacing/bolts
Post by jezza »
I have got 5mm spacers on the front due to my coilovers rubbing on the wheels. Got the fk ones from venom and it says, "Most of the time any size up to 5mm width will mean you can use the factory bolts, any larger than 5mm and you will need to buy longer bolts." Does this mean that i can still run with my standard bolts? Just with the factory ones i only get 3 complete turns then it is tight. Just doens't feel right.
Tim_GTi
Post Whore
Re: Wheel spacing/bolts
Post by Tim_GTi »
I would get longer bolts then mate
vw-po-low
Post by vw-po-low »
Hmm that don't sound right at all. As said by Sir Tim! Get longer bolts.
