Gearbox in, now whats wrong??
Leemo
Post by Leemo »
I have finaly got my gearbox fitted, But when my wife picked up the car from the garage she saw the yellow check light on, for some reason she didnt say anything to the garage :? I have just got in and she has told me about it!! What could it be?? It must be something the garage has done but I did it cash in hand. Im not having a good time with this car, it has only been on the road for two weeks sinse I bought it!! :cry: :cry: I sold my sti import cause I thought it was going to cost me alot.
Please HELP
RandonGUY
Re: Gearbox in, now whats wrong??
Post by RandonGUY »
Is it the service warning light, maybe?
Trottagti
Post by Trottagti »
Even if it was a cash in hand, uv still had work done there so i would take it back n just say can u advise me on the light problem!
I take it, its the engine check light????
Or................
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
Post by emma_88 »
Trottagti wrote:I take it, its the engine check light????
Or................
The gearbox can put the engine check light on?!?! I never knew that at all. You learn a new thing everyday.
Leemo
Post by Leemo »
yes yellow engine check light, the car was bunny hoppin and it has been sittin for a while? Fuel problem??
MaxZ
Post by MaxZ »
The engine warning light could mean so many different things that it's worth checking with the garage using the VAG problem code reader. It could be something as simple as you putting in 95 fuel instead of 97, or could be as erroneous as damaged spark plugs or oil leaking into the engine. Best thing is to get it checked out earlier than later, before more damage gets done.
Tim_GTi
Post Whore
Post by Tim_GTi »
MaxZ wrote:The engine warning light could mean so many different things that it's worth checking with the garage using the VAG problem code reader. It could be something as simple as you putting in 95 fuel instead of 97, or could be as erroneous as damaged spark plugs or oil leaking into the engine. Best thing is to get it checked out earlier than later, before more damage gets done.
Seconded. That light points to sooo many things.
Just take it back to the garage and say it started acting up not so long after you drove it away, and would they mind looking at it.
Leemo
Post by Leemo »
latest update is took it back to garage they checked it over and run it and decided it is bad fuel, maybe cause it has sat for 5 weeks with a full tank and hasn't run at all. He did say that he doesn't have the computer to plug into the car though. So do I run the car then put some new fuel?? 5 weeks doesn't seem that long.
Tim_GTi
Post Whore
Post by Tim_GTi »
Yeh run it down then puyt some new fuel in and see what happens.
Inform the garage though and make it clear what you are doing, so that if the problem is still there after a few fill ups you can take it back and go from there. Otherwise they'll just forget about it.
Leemo
Post by Leemo »
thanks for your help, will let you no how it go's
They possibly left a lamda sensor disconnected. You have to unplug it to remove the gearbox as the wiring is close to it.
