todays progress ::UPDATED::
polo2k
Post by polo2k »
i decided that IF im going to inters (not sure) then nobody is going to even look at my car in its current state, so i removed one of my digits from an orifice i posses and cracked on with the things i have on my mental "to do" list
todays progress was to repaint 2 doors (same side its a 5 door remember) and remove the indents left from removing the rubbing strips which were fibreglassed from the rear and then just left (they could also be welded but i dont have a welder :( yet :twisted: the holes i was left with looked somthing like this:
firstly i got sanding then filled the holes and primered the lower half of the section below the window
then it all got sanded (when dry) with 320 grit then 500 grit and checked for dings etc
then came the bite the bullet time for the color coat which after a lot of masking (as in primering stage) went quite well exept for 2 runs the ill prolly wet sand out tomorrow. please bear in mind that the color match is not exact but after a coupl of coats of laquer if shold be a lot better)
now for the pics
no longer holy
please remeber tht the runs and color match are normal and can be sorted quite easilly with wetsanding and a coat of laquer whic it would need any wat as all metalics are matt without a laquer
Speedlaw
Moderator
Post by Speedlaw »
Damn, I bow down to you...
You, my man, have Grande Cojones for painting your car yourself...
polo2k
Post by polo2k »
the hardest bit was putting the sander on the paint for the first time but after that it was easy just like dioing a customers car
Speedlaw
Moderator
Post by Speedlaw »
So you've painted cars before then? That explains this drastic step then I guess! Coolness. Is there anything you don't do?
polo2k
Post by polo2k »
wheel align ment
rechargeing ac systems and rebuilding gearboxes
the reason why i dont do them is cos ive never been taught and ive never hag a chance to experiment but id like to learn
edit
and typing i cant do tht well at all judging by this post :P
Speedlaw
Moderator
Post by Speedlaw »
I just managed to get it in one go... (Your text)
:lol:
But seriously, I'm well impressed.
polo2k
Post by polo2k »
lol thank you but josh keeps pestering me on msn saying im a guru :oops: :wink:
J-O
Post by J-O »
I tried once to paint the interior piece of the dash board....but the result made it clear: I had to give the pieces to a professionnal :lol: :lol: :lol:
if I wants remove the side strips...I'll do it at the same time as modifying the arches and removing the door handles :wink:
polo2k
Post by polo2k »
if you want it a bit easier try and get some mk4 door panels cos theres no holes and they might be able to do the handles without having the car which mens its in the shop for less time
Speedlaw
Moderator
Post by Speedlaw »
I just realized;
This probably means you're keeping the OE handles, right?
polo2k
Post by polo2k »
for the moment but it wouldnt be too hard to weld up the rears and paint 3 doors next time would it (i like keeping you all on your toes :D)
Speedlaw
Moderator
Post by Speedlaw »
Go on then, surprise us!
:D
Always nice to see new stuff going on.
polo2k
Post by polo2k »
well today i got out the bucket again and poured some laquer on the finish isnt quite what i was hoping for but ill prolly do the handles at some point so then it will be done A1 perfect but for the moment its better than it was :)
so do you all want some pics? well your getting some any way :P
first i did some of this
then some more (note the cloud of over spray :( )
i came forth to conquer :P
it got 2 more coats after this
as you can see no more holes :D yay
as you can see i might give it another coat of laquer or just sand buff and polih but that all depends on how it dries
Speedlaw
Moderator
Post by Speedlaw »
Looking good, from what I can tell from the pics.
Didn't you have trouble with dust and dirt particles sticking to the paint? It's a different kind of paint booth than I'm used to seeing, it's very 'Au Naturel', so to speak...
:lol:
In taking the pics last week I noticed the massive difference in color on the left side of my car, apparently the door had been repainted at one point. Too bad it doesn't match the rest of the car. Any worries about matching issues?
polo2k
Post by polo2k »
it matched quite well but the sky is getting dark now :(
