Rear De-Wipering
Kuru14
Rear De-Wipering
Post by Kuru14 »
Hi all,
looking to dewiper at the rear considering itl look 10x better and the spray doesnt work anyway, a common problem i understand. My question to people who have done it where have you cut/ blockd the water tube as surely whenever the stalk is pressed waters going to escape and leak somwhere?
also does anyone remember what size gromet to use to cover the hole in window.
chewy
Re: Rear De-Wipering
Post by chewy »
First to block the pipe you can bend it over on its self or stick a screw in the end
And for a grommet I recommend here
http://www.gecleant.de/shop/index.php/s ... -/p_3.html
MeTsU
Post by MeTsU »
Nice website. :) Problem is it would cost an awful lot to order one and get it sent to South Africa. Might have to speak to a few mates.
Kuru14
Post by Kuru14 »
cheers chewy, also where did u bend the pipe over itself? i want to do it as near to the resvoir as possible because as it is the pipes broken somewhere along the line i just dont know where yet. do you know where in the engine bay i shud look for the pipe?
thanks
