tip pics?
- whitegtipolo
tip pics?
i need a picture of the tip and the oil breather valve i think mine is the wrong way ?? causing white smoke at idle when hot and left idleing for 10 mins, the oil level never drops or the water?? some one sujested its just fuel as i have no cat fitted?
- KennyPOLO_Gti
Re: tip pics?
It'll be because you removed the cat mate, nothing gettin filtered now, mines does the same, its nothing bad though.
Re: tip pics?
white smoke indicates a duff turbo
blue smoke would be oil
- KennyPOLO_Gti
Re: tip pics?
Is it really bad??? If it has only started snice the cat got removed i would say it would be that? Bet it smells more too!?
- whitegtipolo
Re: tip pics?
yup smells a bit too!
kc
- Drives: an imaginary one... for now
Re: tip pics?
it shouldnt smoke on idle man... at all, unless is cold and condensating obvs lol
only time it should smoke is on full hard boooost
- whitegtipolo
Re: tip pics?
only if left idleing for ages!
