10mm spacers hub problem
chrisjames
Post by chrisjames »
I bought some fk 10mm spacers with a hub locating ring on them. When I fit them the spacer does not reach the hub and there is a gap inbetween. The hole in the middle of the spacer has a bit that goes narrow and it stops it pushing further onto the hub. I have now brocken one spacer so have wasted £40.
Any ideas why they dont fit? What spacers will fit. Can anyone confirm?
Tim_GTi
Post Whore
Re: 10mm spacers hub problem
Post by Tim_GTi »
Tigz had the same problem. He went with 20mm spacers in the end to clear the rear spigots, and 15mm on the front.
You having problems with the rear? Or front also?
h4r1s
Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
Post by h4r1s »
I had the same problem!
was on the phone to venom straight away asking for a replacement.
apparently it's quite common for spacers under 15mm in width
chrisjames
Did they give you a replacement?
Mine have snapped because I tried to tighten them onto the hub
