Blue smoke
polo_GT
Blue smoke
Post by polo_GT »
Can some one please tell me what this is. I raced my friend and when i slowed down he said blue smoke came out my exhaust, is this anything to worry about thanks.
polo2k
Post by polo2k »
blue smoke is usually burning oil
white smoke is steam
black smoke is un burnt hydro carbons
he oil can get into the combustion chambers by lots of was incl#:
failing head gasket
worn rings
crached piston
cracked block
worn valve guides
does she smoke on start up?
polo_GT
Post by polo_GT »
a bit not much though
hardhitter
Moderator
Post by hardhitter »
Its probably going to be something like the valve stem seals or piston rings.
Unless it's getting a lot of oil through the breather, which isn't very likely.
What are the plugs like ? Does it use much oil ?
polo_GT
Post by polo_GT »
the plugs are fine just a light creamy brown colour. And the car doesn't burn hardly any oil. I think it was just because i was ragging it and i use petrol additives which was probably burning off, thanks for the advice though.
