ABS light
avfcnutter
ABS light
Post by avfcnutter »
Right im fed up of the ABS light coming on when people jump in the back, im sure if i ever need it, the light will be on, i had it checked a while back on vag com, its the rear sensor, needs changing, is there just one for the back? and can i buy this and fit it myself?
James
Re: ABS light
Its a faulty cable that connects under the rear seat - not necessarily a faulty sensor. Theres two for the back - namely a left and a right, and both are different so you need to find out which one is at fault.
