gear knob removal urgent
- ppuaar_polosport
- Location: Birmingham Drives - Polo 1.4 16v sport 100 9n
as above cheers
SimonCorrigan
Re: gear knob removal urgent
hi
took mine off a few months ago to put a new gaiter on. pull the gaiter upwards and you should see a crimped metal collar round the gear knob. basically i used a small flat bladed screw driver and brute force. if you mank the collar up to much when taking it off just use a thick cable tie when replacing. once you have removed the metal collar just a hard pull and the knob comes off.
cheers
si
cheers
si
as above but i found the metal clip to be very hard to get off so i used a metal clipper type thing which worked a treat
- ppuaar_polosport
cheers i made a hash of it so i need to be ordering a new one lol
a new what? if ur ordering a new metal clip u can deal without it just use a cable tie or Richbrook do a nice new silver VAG gear knob that i have
the metal clip is there for a reason and should be replaced with it as the gear knob will start to revolve on the gear stick if not properely secured. You wouldn't put a hose on with a cable tie would you. for the sake of a £1 it's better to do it rightJB_UK wrote:a new what? if ur ordering a new metal clip u can deal without it just use a cable tie or Richbrook do a nice new silver VAG gear knob that i have
Yes, the OP should have used two small screwdrivers to ease the crimped ends open a bit - then recrimp it using blunt wire cutters or something like that. I'd be surprised if you can buy a new clip from VAG so maybe you have measured it and are sourcing it elsewhere - if so where for other peoples benefit?
yes you can buy from vw I had to when upgrading to gti spec I am sure it was about a quid but certainly readily available.RUM4MO wrote:Yes, the OP should have used two small screwdrivers to ease the crimped ends open a bit - then recrimp it using blunt wire cutters or something like that. I'd be surprised if you can buy a new clip from VAG so maybe you have measured it and are sourcing it elsewhere - if so where for other peoples benefit?
Part number for the clip is N 100 811 01hope this helps 76p + vat 89p total for the sake of less than the cost of a cheeseburger do it right and yoou waist will feel better as well lol.
