How To Remove Front Grille
V-MaN668
Post by V-MaN668 »
Hey people,
Just wondering how difficult it is to remove the front grille, under the bonnet i can see four screws which secures it, but once these are off, do i just yank and pull the grille off? Any ideas would be much appreciated. Thanks.
V-MaN
Dennis
Re: How To Remove Front Grille
Post by Dennis »
just like you said: take the 4 screws off and just slowly pull the grille off 8)
aaronon
Post by aaronon »
You unscrew the four torx screws.
After this you look under the bottom line of the grille face on. Stick your hands in and you will feel a clip on each side. These clips hold the bottom of the grille onto little latches on the body of the car.
Get a flat screw driver and push the clips towards the car (therefore pushing the clips out of their little holders) and pull the grille out.
charlievwp
Post by charlievwp »
VMan - hi and welcome....did my advice previously not help you? :roll:
