immoboliser codes 17978 & 01176 keep coming up
f1basgh
Post by f1basgh »
I have a Year 2000 Polo 1600cc Petrol Estate S ,and when I put my genuine VAG Scanner Code Reader it keeps coming up in the engine section with error code 17978 - P1570 Engine start blocked by immobilizer . Then in the Immobilizer section Error Code 01176 Key - Sporadic Signal to low . Only thing is the car starts every time 99% of the time , just every so often it starts then stops immediately but will restart the next turn of the key . Any one any ideas please . Tony
Rob Renegade
Re: immoboliser codes 17978 & 01176 keep coming up
Post by Rob Renegade »
I had this problem and it was down to my battry having a dodgy cell in it - although that unlikely
it can be down to the antenna being in slightly the wrong place (the antenna is round the ignition barrel)
Also i know that having a shed load of keys on the same key ring can cause problems.. blocks the signal ?
Hope this helps
Rob
