VAGCOM fault codes
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
VAGCOM fault codes
Post by emma_88 »
Finally got round to running vagcom on my polo last night. Came up with the following fault codes - The engine check light has been on for quite some time but I've chose to ignore it 'cos it hasn't affected its performance...
VAG-COM Version: Release 409.1-S
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01: Engine
Controller: 036 906 033 D
Component: 1.6l/4V SIMOS3 00HS3512
Coding: 00031
Shop #: WSC 00788
WVWZZZ6NZ1Y258339 VWZ1Z0A1314622
3 Faults Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-00 - -
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - Please Register/Activate - Intermittent
16517 - 16517 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 1) B
P0133 - 35-00 - Please Register/Activate
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 6X0 907 379 C
Component: ABS/EDS 30 IE CAN V004
Coding: 15603
Shop #: WSC 00788
So basically what I'm looking at is replacing the camshaft position, lambda and O2 sensors... Yeah? Anyone have any idea of how much these sensors will cost me from VW? And are they easy enough to fit etc...
Re: VAGCOM fault codes
I wouldnt worry too much about lambda and o2 sensors - just check all the wires are plugged in from the cat and manifold.
As for the sensor, my one went too :( Its the sensor on top of the rocker cover to the right hand side - just order one of those up and youll be done!
emma_88
Post by emma_88 »
How do I know which lambda sensor it is that's causing the fault code to come up? I've looked on euro car parts and there's about 5 difference lambda sensors!
Oh another thing - ECP don't stock a camshaft sensor? Is there another name for it?
Im pretty sure the VW part number is 030907601B or C depending on your chassis number - best thing to do is remove the old one and take the part number off that.
I strongly recommend getting a genuine VW one as this sender when supplied as copy parts tend to fail
emma_88
Post by emma_88 »
alexperkins wrote:Im pretty sure the VW part number is 030907601B or C depending on your chassis number - best thing to do is remove the old one and take the part number off that.
Thanks Alex. I'm assuming you're on about the camshaft sensor? Any thoughts on the lambda sensor?
