9N3 1.4S Interior Light
Manxy
Post by Manxy »
The interior light is staying on when it is should be controlled by the doors. Where do I find the switch?
chewy
Re: 9N3 1.4S Interior Light
Post by chewy »
If your on about the switch on the door its built in to the hinge iirc if not then its the lock
As for the switch at the light the whole light cover moves as switch
Manxy
Post by Manxy »
Thanks I am pretty sure it is the switch in the door that is sticking and leaving the light on when the door is closed. It can be turned on/off manually at the light.
