black roof lining
red6n2
black roof lining
Post by red6n2 »
... anyone got a clue how i can do this ???... its looking like fabric spray might be my best option... also i have a sunroof so this may make it more difficult !
Tim_GTi
Post Whore
Re: black roof lining
Post by Tim_GTi »
Yep I've currently finished the pillars and are working on the roof.
The pillars will take spray adhesive, the roof want take so kindly.
I'm looking at probably using a tape on it next time. And the sunroof will be alot more hassle!
red6n2
Post by red6n2 »
what do you mean by tape... ?
i met a guy who had spray glued some material onto it and his pillars looked awesome... want the name of the spray ? he gave me the can but its in my boot he said its heat protected up untill about 80 degres or somwhere near there
i love my sunroof but it dosent half cause some hassle !
Tim_GTi
Post Whore
Post by Tim_GTi »
the glue is called evostik, works really well fabric to plastic.
tape as in fabric tape such as wonder web, or maybe duck tape, i haven't decided yet. i've got alot of spare to toy with though which is good.
wheelmanwayne
Post by wheelmanwayne »
see a man called babz on clubpolo he has the most lush interior you will ever see cream/brown with orange leather
paulzpolo
Post by paulzpolo »
spray glue, carpet adhesive, will do, can be got from more diy stores if your old enough.....
to change the colour of your head lining, it will have to be removed, once removed, you could spray it with normal rattle tin,spray paint,think that satin black should to
duck tape, wtf are you thinking.........it will look total s**t
Tim_GTi
Post Whore
Post by Tim_GTi »
paulzpolo wrote:spray glue, carpet adhesive, will do, can be got from more diy stores if your old enough.....
duck tape, wtf are you thinking.........it will look total ****
I think the question more is: spray paint, wtf are YOU thinking. That's fabric you'll be spraying, it would look awful!
When I was talking about duck tape, I was referring to it as a form of adhesive to this black suede fabric I already have to go on top of my roof lining. I've already tried spray adhesive, and it didnt take to well to the fabric, has stuck the pillars fine:
So instead I'm going to try some forms of tape as it seems this would probably do the trick.
paulzpolo
Post by paulzpolo »
it is a well known trick of the trade, when a car comes in and some t**t has cut stupid big holes in a parcel shelf, and they cannot get a second hand one the corrct colour, they use satin black spray paint to colour the material, if the car has a dark interior
secondly
duck tape, is also known as bodge tape usually 2" wide and is pretty good at sticking most things
what you are talking about, is probably double sided tape, which carpet fitters use to stick carpet down with,
i have built many a car audio system, in more cars you will ever own, and spray glue is the best way of sticking it to trim, if you read the instructions correctly and follow them it will work a treat
prick
Tim_GTi
Post Whore
Post by Tim_GTi »
Paul if you want to continue using this forum, I suggest you don't personally insult other members such as myself. I'll let it slide this time. But don't do it again as it can result in a warning and a ban, simple fact.
I'm happy with using my own methods to do my own trim, as I've very succesfully done all the pillars, and are just awaiting some time spare to finish off the roof, I don't require your help (As I can see we quite clearly clash heads), was just trying to help out another member with successful methods I found out myself.
red6n2
Post by red6n2 »
thanks for the help guys... i have a habbit of messing things like this up... badly so i will weigh up my options and then let you know which way i choose although i am leaning more towards tim's method, it just seem like less room for error...
... maybe start in the next few weeks, got some other stuff to sort out first...
:D :D :D
Tim_GTi
Post Whore
Post by Tim_GTi »
Any problems give me shout mate 8)
babz
Post by babz »
heres mine....
black suede roof lining ABC pannels, sunvisors and tweeters, with black seels
and orange trim
Babz
Tim_GTi
Post Whore
Post by Tim_GTi »
Looks good mate. how did you the cream edges of the lining that are connected to the rubber seals?
red6n2
Post by red6n2 »
i saw that at edition... was parked on the show fireld next to another 6n2... very nice :D
babz
Post by babz »
thanks....
the sills i used, well not me but interior place used fabric dye i believe, but the spray will work too.
Babz
