Wee problem! wheres the polo mk 4 experts?
kyle_mk3
Post by kyle_mk3 »
temp light keeps flashing up on dash, have replaced the sensor under the bonnet after a few reccomendations and still no joy have also tried disconnecting the switch at the expansion/water tank, temp isnt going past half way which im told is completely normal. does anyone have any ideas what could be causing this? if so can they drop me a email at the address below n let me know asap please.
cheers kyle
(kyle20032004@hotmail.com)
kyle_mk3
Re: Wee problem! wheres the polo mk 4 experts?
Post by kyle_mk3 »
ok after taking it to an audi/VW garage its now went off....was on when i got there but when i stopped the engine and went in n got the mechanic who revved the arse out of it, it wouldnt go on again.....even after takin it 4 a long drive. is it a case of reset of the ECU? if so can it be manually done?
NOZ
Post by NOZ »
Just disconnect the battery for an hour, which resets the ECU.
Jay77
Post by Jay77 »
Hi Kyle
I have the same problem as you, did you try what Noz advised you if so did it work and did you encounter any other problem?
kyle_mk3
Post by kyle_mk3 »
it didnt work, the light went off for no more than a day then back to flashin up...any luck on yours?
