Hi i am having trouble with the spring at the top of the brake drum that has something to do with the self adjust mechanism. I have not seen a set up like this before and the spring had come loose before i started so did not see how it went together. Has anybody had their drums apart and if so how do you put the self adjuster mechanism back together.
Thanks.
Drum Brake help
Re: Drum Brake help
This is the area/spring i am talking about.
