Help fitting central locking kit
mysticalvibes
Post by mysticalvibes »
Hello, I'd really appreicate if some here could help me out. I;m looking to fit a central locking kit to my new VII facelift polo. I have a kit which i bought from ebay whic has the following connections -
Locking -
White = Common
Orange = Normally Open
Yellow = Normally Closed
Un-Locking
White with Black Stripe = Common
Orange with Black stripe = Normally Open
Yellow with Black stripe = Normally Closed
I have tested the connections with a multi-meter and when I connect the Common wire to the orange wire and press the lock button on the remote when circuit "closes" for a few seconds then return to it normally "open" position. When the Common wire is connected to the Yellow wire and press the lock button the circuit "opens" for a few seconds then returns to its normally "closed" position.
The same response occurs when you test the other 3 wires in the same way.
Depending on your system you only use 2 wires from the lock / unlock options.
If anyone can understand my babble and has any idea which wire colours at the door lock/unlock switch would corrospond to these wires i'd really appreicate their help.
Davy
