looking at converting a polo sdi using a tdi pd 130 or 150 engine out of a mk 4 golf tried using the search couldnt really find anything on this subjects so anybody done this or can offer anyhelp
cheers mort
golf tdi engine conversion
Re: golf tdi engine conversion
the golf tdi gt versoin has more power, i rekon if a 1.8t and a 2.2 can fit thn a tdi engine should fit, there more or less the same size, best asking a garage or somebody who will give you a definate yes or no, or jus measure the engine ya want t the size u can fit the engine in..... hope this helps
yh im sure it would physically fit in the engine bay
obviously gotta fit the intercooler and turbo in as well
use ecu from golf
generally im after
are the engine mounts the same ?
which gearbox to use?
use ecu from golf
generally im after
Youl need a complete TDI engine, engine loom, interior loom, clocks, immobiliser and key throttle pedal etc, youl need a 5 speed gearbox from a lower power diesel golf, the mounts are completely different, then youl have to swap over the plugs for the inerior switch's etc, immobiliser and key arnt that important as revo or AmD essex can immobiliser defeat the ECU. the conversion has been done before no more difficult than doing a 1.8t conversion realy easy 190bhp with a remap and upto 260bhp with a hyrid etc
cheers big4244
so the 5 speed fits fine from the golf no chance of using the box thats already in the polo?
and use the standard polo shafts?
some info on here if anyone finds thread through the search
http://forums.tdiclub.com/showthread.php?t=142679
is there any build threads anyone had seen involving this ?
cheers mort
cheers mort
Get down to a breakers mate, like steves vw, and ask to have a look at both blocks out of the engine too see if they mount the same. I have always believed that the sdi is just a non turbo pd lump anyway as they look pretty similar. Its a conversion I have been thinking about even though I'm putting the 2.0l in mine. If my suspicions are right then it should be a straight swap but I can't say for defo. I'd hope it would be just a case of stripping both blocks down swapping mounts and anything else you need and running everything in new places. My main concern would probably be how much room you have for the turbo itself!
The standard polo gearbox is like chocolate & can't deal with 100bhp of 1.4 16v, so the 150+bhp of a TDI lump with the buckets of torque it produces will rip it apart.mort1414 wrote:cheers big4244
Defo have to use the golf's gearbox!
CV ends need changing but you can sue the standard driveshafts. Figured that out the other day. Polos have i think its 90mm cv ends golfs use 100's. Or atleast my 2.0 box does!
