mk 4 door rubbing strips
One of my door rubbing strip's has come unstuck at one end . What is a suitable adhesive to stick it back down???
racerjonzo
Re: mk 4 door rubbing strips
depends if your paint is coming off behind it aswell, if not then i imagine glue, but perhaps i can persuade you to just take them off?
easily done, apparently
nah its just some hot water over the top and a slow but steady pulling to prise it away, be careful this can pull the paint off
if done correctly and polish off the glue residue, youll be left with a nice smoothish looking door ( minus bump strips)
hope this helps.
John
hope this helps.
John
Thank's John but I prefer the strip's to stay on.
This stuff will do the job: Clicky
Best to take the strip off completely, clean both the strip & bodywork off & then re-apply it.
