hi guys guess a thought here, iv got myself a mk4 6n polo 8v 90000 miles on the clock, iv noticed that the engine temperature gauge seems to get up to temp then start to idle up and down but not going past the normal temp (half way on gauge) its had a new thermostat in it about a year ago. anyone got any ideas??
also i notice that on my exhaust seems to drip abit of water/condensation with some smoke sometimes. now im fearing the worst e.g. cracked head, cracked block and not so bad head gasket. need some help asap on that.
cheers
MK 4 idling temperature etc
- Darby Vw polo
Re: MK 4 idling temperature etc
How quick does the needle move side to side? If it's slow then it probably is the thermo OR the fact the days are getting colder now so its messing it around.
Can't remember but I recall hearing that water/condensation out the back is a sign your engines running clean!
Find out first before taking my word for it lol.
- Darby Vw polo
it is slow but it gets up to temp first then after a few minutes it starts to go up and down, slowly but noticalbe
maybe the temp sensor? my boyfriend and I brought a 6n recently R plate on 44k milesDarby Vw polo wrote:hi guys guess a thought here, iv got myself a mk4 6n polo 8v 90000 miles on the clock, iv noticed that the engine temperature gauge seems to get up to temp then start to idle up and down but not going past the normal temp (half way on gauge) its had a new thermostat in it about a year ago. anyone got any ideas??
the tempreture gauge doesnt move its just stuck at the bottom. we're about to put a new temp senor on hopefully that will work. its light a little thing that costs around £10.
might be yours is faulty to which is causing yours to go up and down.
cheers
how much have you driven the car and how much was it driven before you got it?
if its not been used much recently give it a good couple of revs should blow all the water out hopefully.
hoping all is ok and its not anything worse!
- Darby Vw polo
yeah iv noticed that the water out the back of the exhaust is only when i start it up but when it gets warm its fine, i think it cud be the termostat.
racerjonzo
yea my temp sensor went not long ago, said the car was overheating when i just turned the enigine over. replaced the sensor, all works... the sensor on these things are pants heard a few other gone from other forums
:P
hope youve got it sorted now mate
- Darby Vw polo
yer m y bro had the problem of it saying it was cold all the time, i had it not long after having my mk4 then changed it. so im gona change it at the weekend. hope all goes well.
