Could anyone suggest some springs?
VDUB-Polo
Post by VDUB-Polo »
Looking for a set of lowering springs to lower 60mm. My brother got some OMP springs direct for £60
Suggestions?
bnub24
Re: Could anyone suggest some springs?
Post by bnub24 »
The lowest springs you can get dude are 55mm lowering springs and supersport make them you can get a set off of venom motorsport for a mk 6 polo but they are the same as the mk7 mate.
If you want 60mm springs your going to have to go down the route of coilovers dude thats the only way you will get your motor down to 60mm or more.
The dampers will get fudged as well mate if you go lower than 30mm or 40mm after a while. I would go for coilovers mate then you can raise the car and lower it when you want.
VDUB-Polo
Post by VDUB-Polo »
Ok thanks =)
ransonneil
Post by ransonneil »
my 30mm eibach ones i suggest, need shot of them ha
VDUB-Polo
Post by VDUB-Polo »
Well i've got 17's on atm, and it seems like i need to go 50mm+ to make it sit right.
noone025
Post by noone025 »
My shocks died in about 5000kms with H&R springs. If you go low, you may be up for some new shocks on the front after not long...
loud
Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
Post by loud »
I've done over 20k with the H&R's on standard shocks and still no problems, so would recommend them
GuyGTi
Post by GuyGTi »
What coilovers are decent then but not £££. Am i right in saying that coilovers make it much stiffer than say a uprated kit?
bnub24
Post by bnub24 »
AP's are meant to be pritty good, a mate of mine had them fitted to his and has never had any problems and he has had them one for near a year wound all the way down. Dont get Jamex or v maxx coilovers mate there known for there unreliability when they are wound all the way down, the dampers start to go.Coilovers do make the dampening stiffer, usual coilovers run at about 30 percent but some can vary.
jimlad09
Post by jimlad09 »
i see this hasnt been an active topic for a while but it suits my question. i am getting mine lowered in the next week or so and im looking to buy the springs over the web. what lowering springs shud i go for as i dont want any side effects as i enjoy driving enthuasiastically and want handling improving not hampering. any advice would be brilliant!
