Camber Adjustment
Brad.
Camber Adjustment
Post by Brad. »
Is there any chance someone on here could get me a picture or explain in detail, which bolt I need to do undo to adjust the camber on the passengers side front wheel?
Thanks alot,
Brad.
Bepe
Re: Camber Adjustment
Post by Bepe »
the 2 big bolts that attacth the bottom leg of the suspension to the hub, undo them and pull the disc brake towards you and hold it there while tightening the bolts up
Brad.
Post by Brad. »
Thanks bro
