fuses question [SOLVED]
rapid_f1
Post by rapid_f1 »
Hi all, bit of a weird one - in my x reg 2000 where the fuses are (right of steering wheel) I have 3 rows of fuses. however not every slot has a fuse in it, in fact the middle row has barely any fuses in. Is this normal? Do you guys have a full compliment of fuses installed?
david burton
Re: fuses question
Post by david burton »
Perfectly normal if you don't need the fuses - usually for optional extras. Relays are more common to be missing.
acid drop
Re: fuses question
Post by acid drop »
Often wondered why there are empty spaces in fuse boxes
rapid_f1
Re: fuses question
Post by rapid_f1 »
If anyone is interested here are the fuses, their type in the order they should be in. This is for a 1.4 polo 2000 petrol manual, fron electric windows only.
