Grinding Steering Wheel?
Post by 5509433 »
After a long drive from essex to bournmouthe (sp?)
My steering wheel has sudenly started making a rough grinding noise.
Any ideas?
Gary Gee
Re: Grinding Steering Wheel?
Post by Gary Gee »
mine did this... it was git between the steering wheel and the boss sort of thing... i just wedged my srew driver lmao
Bepe
Post by Bepe »
Just spray Abit of wd40 in there mate, that'll sort it out like gary says its Abit of grit
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
Post by emma_88 »
Mine does this too on my gti.. Does my head right in, but I've gotten used to it. If WD40 does the trick I'll be well chuffed!
Jordy-6n2
Post by Jordy-6n2 »
mine too, am gonna leave it and not make my car smell of wd40
Verity
Post by Verity »
my old 6n2 E did the same thing. greased it. stopped it :)
emma_88
Post by emma_88 »
Verity wrote:my old 6n2 E did the same thing. greased it. stopped it :)
Do you have to actually take the steering wheel off? Or just spray the WD40 etc into the crack bit? lol, I'm so crap at explaining stuff.
lolhoward
Post by lolhoward »
If I remember correctly theres two small metal contacts between the steering wheel and rack. Poss for air bag. Mine had a bit of dirt on. Cleaned them and sprayed them and that sorted it.
Dont use WD40 though. Buy a decent silicone spray, alot safer and better.
lolhoward
Post by lolhoward »
Didnt remove the wheel. You should be able to see them and get a small screw driver or cloth in there.
Bepe
Post by Bepe »
Wd40 is fine. Oh you may have to remove Abit of the cowling to get right in there. Only a couple of short blasts is needed
randomage
Post by randomage »
Lolhoward is on the right track. there is a metal contact between the wheel and the boss, I think it gives the wheel a connection for the horn and (if fitted) the airbag. Just put in a bit of grease and bend the rod(s) so they run on the metal plate of the boss more smoothly. (Assuming you can get at it, I had this problem on my old 6n and it was easy enough to get to on there)
