Grinding Steering Wheel?
Posted: Mon Nov 09, 2009 12:29 pm
by 5509433
After a long drive from essex to bournmouthe (sp?)
My steering wheel has sudenly started making a rough grinding noise.
Any ideas?
Re: Grinding Steering Wheel?
Posted: Mon Nov 09, 2009 3:21 pm
by Gary Gee
mine did this... it was git between the steering wheel and the boss sort of thing... i just wedged my srew driver lmao
Posted: Mon Nov 09, 2009 7:33 pm
by Bepe
Just spray Abit of wd40 in there mate, that'll sort it out like gary says its Abit of grit
Posted: Mon Nov 09, 2009 8:21 pm
by emma_88
Mine does this too on my gti.. Does my head right in, but I've gotten used to it. If WD40 does the trick I'll be well chuffed!
Posted: Thu Nov 12, 2009 12:25 am
by Jordy-6n2
mine too, am gonna leave it and not make my car smell of wd40
Posted: Fri Nov 13, 2009 10:39 am
by Verity
my old 6n2 E did the same thing. greased it. stopped it :)
Posted: Fri Nov 13, 2009 12:10 pm
by emma_88
Verity wrote:my old 6n2 E did the same thing. greased it. stopped it :)
Do you have to actually take the steering wheel off? Or just spray the WD40 etc into the crack bit? lol, I'm so crap at explaining stuff.
Posted: Fri Nov 13, 2009 12:39 pm
by lolhoward
If I remember correctly theres two small metal contacts between the steering wheel and rack. Poss for air bag. Mine had a bit of dirt on. Cleaned them and sprayed them and that sorted it.
Dont use WD40 though. Buy a decent silicone spray, alot safer and better.
Posted: Fri Nov 13, 2009 12:40 pm
by lolhoward
Didnt remove the wheel. You should be able to see them and get a small screw driver or cloth in there.
Posted: Fri Nov 13, 2009 2:45 pm
by Bepe
Wd40 is fine. Oh you may have to remove Abit of the cowling to get right in there. Only a couple of short blasts is needed
Posted: Sat Nov 21, 2009 1:19 pm
by randomage
Lolhoward is on the right track. there is a metal contact between the wheel and the boss, I think it gives the wheel a connection for the horn and (if fitted) the airbag. Just put in a bit of grease and bend the rod(s) so they run on the metal plate of the boss more smoothly. (Assuming you can get at it, I had this problem on my old 6n and it was easy enough to get to on there)
