In all my past Golfs etc, I had the variable interface relay where you could switch on the wiper to interval, switch it off straight away, then back on and that would be the interval time.
Tried that today on the Polo and noticed that it did not work. Is that not a standard feature and if not, is it a case of swapping a relay again?
No variable interval?
Re: No variable interval?
Its just a case of swapping a relay mate
Any links for the required relay, Alex?
i think there is a guide in the DIY section. Ill see if I can find the part number
Found it in the DIY section, thanks. Just doing the ebay bidding now
Thanks again Alex.
Thanks again Alex.
Ok, bought the part from eBay now for the mighty sum of £2.70. Should be here in the next couple of days, worthy upgrade for the money.
