door seals
door seals
hi all been finding alot of water in my passenger footwell had the carpet up doesnt seem to be wet by the centre consol or the piller by the dash. put carpet back again and dryed it out a lil went out again 2day in the rain and it looks like its coming under the door over the door seal how do i stop this happening any1 else had this prob??
Re: door seals
Someone else posted not that long ago about this!
Check this out http://www.uk-polos.net/view ... 256d124fc9
Hope this helps
Hope this helps
Re: door seals
thanks iv read that post not all that useful really what i would like to no is is it as simple as changing the door seal or is it more complicated than that??
Re: door seals
Well like the others did, I would first check the scuttle, if that is filled with water then that is most likely to be the problem, if it's not that then I think you have something more serious on your hands, if your not an expert probably best to get it looked at..
If you need any more help, just ask
Re: door seals
ye iv done this and iv also replaced the doorcard membrane think i might just bight the bullet and get a new seal see wat that does hopefully that wil stop the water traveling up and over it
Re: door seals
Well once you checked it and replaced the door car, was there still water coming in?
If so you probably will need a new door seal!
