Auto Glym Super Resin Polish Is pretty good mate, i wouldnt put T-Cut anywhere near my cars paintwork, afterall you do wanna keep your paint on your car? oh and is your car metallic or a solid colour because if your using T-Cut on a metallic car then your going to ruin yours!
im tempting todo this but i cba to get it touched up or anything if it goes terribly wrong soo whats the best way to do it? wire and hair dryer? or this DW40/GT45 way anygood? if so how do you do it?
Ian it's dead simple, hairdryer to warm the foam and get some thin wire (guitar string or fishing wire) and just cut the foam so the badge comes off. WD40 works ok yeh, there's a few abrasive polishes that do the trick too. Autoglym bug and tar remover ain't bad either.
I just used the hairdryer and my fingers. You have to heat the badges quite hot (i.e. so you can hardly touch them), then you can just pull them off with your fingers.
If possible, don't use anything in between (string or not) as anything touching paint has the risk of damage. Patience and heat is all that is needed (and strong fingers ...).
