The ABS light came on so I took the car to VW, they replaced both the rear speed sensors. Two weeks later when the car is full, the light comes back on? But only when the car is full.
Anyone else had this problem? Or know of a root cause or solution?
Thanks, Renk.
Mk5 2000W Volkswagen Polo ABS Problem
avfcnutter
Re: Mk5 2000W Volkswagen Polo ABS Problem
Hi there, i had the exact same problem with my MK5, very annoying, im pretty sure its to do with the connection under the rear seats, flip them up and have a poke around with the wires, see if it helps.
James
James
- Tim_GTi
- Post Whore
Yep it's the connector under the seat, happened to me many times. Although I've never located it myself.
