any1 has kw coilover on their gti?
khfluk
Post by khfluk »
i had a set of v2 on my previous peugeot 306, they worked fine but the problem is that i didn't really need the rebound adjustment.
so i am thinking to get a set of v1.
are there any big differences between v1 and v2? and how many mm exactly can the front and rear lowered? some said it's 35mm, some said it's 45mm...
appreciate if any1 can help.
cheers
david burton
Re: any1 has kw coilover on their gti?
Post by david burton »
Got V1s on my TDI, they go about 45mm at the back and as low as you want at the front. Can't compare to V2s but the ride is pretty good considering I'm on 17s. I tend to have to avoid potholes though and with a full car it's a bit bouncy. I expect V2s would solve that issue.
