Hey
will the below spec fit a mk5 polo? offset is the main concern as not sure if they would fit the car.
15 inch diameter, 7 inch wide, offset 25, the center bore is 57.1, 4 stud.
Thanks in advance
will this spec fit my mk5 polo 15 inch diameter 7 inch wide
Re: will this spec fit my mk5 polo 15 inch diameter 7 inch wide
yep it will, but how low are you is the question?
only 40mm drop currently got bbs rm's 6jfront & j7rear with no issues.
Thanks for letting me know.
