Remote central locking. How easy to fit?
polo_mad
Post by polo_mad »
Hi everyone, about to order a remote central locking kit. As the barrel is about to go on the driver's side!
Are they hard to fit? and is there a guide on here at all? would be very handy.
cheers.
Re: Remote central locking. How easy to fit?
Do you already have central locking in your car? If so, its dead easy...just a few wires to connect to the pump in the boot and the indicators at the back :)
polo_mad
Post by polo_mad »
i do yes. is it that easy? what kit would you recommend?
indeed mate. rclick.co.uk get one of their remote central locking kits :)
pvr
Post by pvr »
Took me 20 minutes to fit. The longest job was feeding the indicator cable to the other side of the car.
I fitted it in the panel in the boot nex to the central locking pump, easy access (was needed recently when one of the keys died and I got a replacement).
red6n2
Post by red6n2 »
my rclick thingy has stopped working !, if i press lock or unlock on the key then the devise makes the clicking noise but isnt activating the pump... i never attached it to ythe indicators as i wasnt really sure on what i was doing.
do i need to send it back or is it a simple solution... ?
fuse is fine, its earthed my amp in my boot so thats fine lol and the yellow and yellow/black are connected... so i really dont get it !
oh i should point out... it did used to work just randomly stopped but the blue flashing light is still working and flashing away
sounds like a faulty controller box. Where did you take the live from for it?
red6n2
Post by red6n2 »
its earthed and live from my amp... not the best place i know but ity works lol well did work, you suggest a better place ?
pvr
Post by pvr »
Live from the centrol locking ... You joined all the live wires together from the kit?
red6n2
Post by red6n2 »
you mean the yellow and yellow/black yup done that... i think im going to send it back as a faulty item and see if i get a new one
try a different earth and live - perhaps piggy back onto the central locking pump wiring (thats where I would connect it permanently anyhow)
red6n2
Post by red6n2 »
my friend just installed mine... it... is... AWESOME ! indicators the lot im well chuffed all that need doing is the led set in place properly its at the front of my car just need setting in its place but i shall do that tomorrow :D :D :D
Kayne West isn't the only one with flashing lights
Post by 5509433 »
Yes, it is very easy!
How ever i too have come to it not working.
It only works some times?
It will ALWAYS unlock.
But some times it wont lock.
Im thinking of re-installing it with different connectors. Maybe block terminal connectors.
As red said, it will click, but it wont do any thing.
lowfoon
Post by lowfoon »
Check the central locking pump by drivers door, in the inside of the drivers footwell for any air leaks...
Post by 5509433 »
it wouldnt be an air leak, because it works fine with the key.
And when the fob works, it works great to. But some times nothing happens other then the one flash of turn signals.
