Aero Wipers
quiksilveralex
Aero Wipers
Post by quiksilveralex »
Hay
Right as the title suggest I’m after getting some retro fit aero wipers for my 6n2. The question is are these available from VW and if so what is the part number and how much would I be expecting to pay? If not where’s the best place to get some?
The next question concerns the rear wiper as I also wish to change that to an aero type. Now after reading on here I found out that it’s either got to be the 9n polo wiper or the passat estate. I also read that it may require some modification in order to make it fit properly what does this involve? Although I did notice on one thread that someone said there was a thread in the DIY section for fitting an aero rear wiper to a 6n2 but unfortunately I couldn’t find it maybe someone could point me in the right direction.
Anywho sorry for asking so many questions! Any help is appreciated :D
Thanks Alex
Re: Aero Wipers
6N2 998 002 is the code for the Aero front wiperblades from VW. They are about £18 for the pair and are very good quality
the arm is 6q6 955 707 c
the cap for the arm is 6q6 955 435 b
the blade is 3c9 955 425
Above is the Part Numbers for the rear wiper. All that is needed to be modified is to push the clip on the blade off center so that the blade lines up properly on the windscreen - its very easy to do
Any problems let me know
emma_88
Drives: 6N2 Polo GTi & 9N3 Polo GTi
Re: Aero Wipers
Post by emma_88 »
alexperkins wrote:6N2 998 002 is the code for the Aero front wiperblades from VW. They are about £18 for the pair and are very good quality
Which rear wiper is that Alex? 9n or Passat???
EDIT - Nevermind, had a search on ETKA and it's the 9n.. Duh. Silly me.
quiksilveralex
Re: Aero Wipers
Cheers Alex Hopefully get all this from vw over the weekend along with a few other goodies :D . Will let you know if I have any problems
Thanks Alex
Re: Aero Wipers
The arm on the passat and 9n is the same :P Its just the blade thats different!
No worries.
