Brake Disc Sizes for the GT TDI
GR33NIE
Post by GR33NIE »
What are the standard sizes? I seem to be reading contradicting info lots of different places :(
Are they 288mm on the front and 233mm on the rear??
g__humm
Re: Brake Disc Sizes for the GT TDI
Post by g__humm »
the fronts are 288 but cant tell you bout the back
Tony_
Post by Tony_ »
Back are 232mm ;)
GR33NIE
Post by GR33NIE »
Awesome thanks folks, means I can finally get some priced up online :D
GR33NIE
Post by GR33NIE »
Still a mission to order these, well the discs are fine but apparently 2 lots of pads were fitted to the GT TDI and TDI Sport so I need to find out which pads are the correct ones. Pretty sure I read somewhere you can find this with the chassis number or something!?
Dub_Dan
Post by Dub_Dan »
why not just ring vw or a specialist mate?
pip_polo
Post by pip_polo »
GR33NIE wrote:Still a mission to order these, well the discs are fine but apparently 2 lots of pads were fitted to the GT TDI and TDI Sport so I need to find out which pads are the correct ones. Pretty sure I read somewhere you can find this with the chassis number or something!?
Go to VW, and they will just ask for your reg number. Then get part number and go somewhere cheaper ;)
GR33NIE
Post by GR33NIE »
Sussed it out now, cheers for the help everyone
Basically there is x2 different pads that went on the GT's. Quite easy to tell the difference they are actually a bit of a different shape. Think i'm gunna go for some EBC brakes all round ;)
