Is it just a matter off pulling the fog light surround out to see the tow eye hole?
Dont suppose anyone knows the size off the bolt that will fit into it?
Bit off a long shot i know, but erm................Alex? lol!
Front tow eye/grill removal!
Re: Front tow eye/grill removal!
unscrew the foglight cover and you'll see the screw hole, now get your toolbox from the spare wheel and you'll see the tow eye now screw it into it but if i remember correctly its opposite threads so the normal way you undo things is to tighten up!
- Trottagti
they just little torques then holding the cover on?
1x Phillips screw if i remember correctly.
