Headlining re-trim
- spudisdabest
Headlining re-trim
i have a sunroof model, and i know its covered lots but not specifically for sunroof models. 2 questions:
control unit for the electric sunroof, how do i remove it to get the headlining out?
pillars, do these just prise off?
a walkthrough for a 6n2 would be fantastic if anybody knows of one, thanks!
ps. quick replies would be good as im hoping to fetch it out tomorrow!
- red6n2
Re: Headlining re-trim
supposed ti rai tomoz, is it not best for a weekend jobor even a long weekend job so its not rushed ?
- spudisdabest
It won't be a rushed job as I don't mind driving around without a liner for a few days just need that bit of info before I start
With removing all parts is easy, other then ive never tried it with the sunroof model.
But remove all handles, lights, pillars, rubber seals, visors etc
To remove the panel, i believe its the case of prying it off.
- spudisdabest
cheers pal..im about to attempt it now so il let you all know how it goes!
- red6n2
hows it going ?
- spudisdabest
All done! Not as hard as I thought! Just scary pulling your car apart! Will get all te pictures up later on!
- red6n2
what have you actually done ?
- spudisdabest
retrimmed the headlining in a different fabric. many people do it, but only a handful have done it to a sunroof model
- spudisdabest
did a DIY guide. will upload finished pictures tomorrow!
http://www.uk-polos.net/view ... 10&t=47603
- red6n2
nice one.. i have a sunroof and want black headlining but i wouldnt have had a clue how to do it... i might give your guide a go in the summer.
with projects like this im let down by two floors... im heavy handed and very impatient lol
Nice one mate! How are you going to go about doing the sunroof slideing cover an handle?
Also, did you boot have to be empty to remove the c pillars?
- spudisdabest
its relatively easy. i was a bit aprehensive to begin with as ive never done anything like this before.
as for the sunroof cover im still a bit bewildered as how to do it. i didnt remove the c pillars completely i just removed the top clips and slid the headlining forward then back out of the boot.
So with the roof lining out, can you remove the sunroof cover?
Or is there something else in the way?
Im off to VW now, so ill ask them about the sunroof cover handle.
Because i dont want to pry it off, and find out its glued! lol
- spudisdabest
you cant SEE any fixing from the underside. i think you would be able detatch it but it would be a case of removing the whole sunroof unit to get to the fixings which in my eyes aint worth the ball ache.
