drivers side swithch out
- red6n2
... any ideas is there a bulb that needs replacing and would this have anything to do with it not working ?
Re: drivers side swithch out
Which switch are you referring to mate
- red6n2
lol my bad the drivers side window switch...
those washer jets arrived today fitted em and there a lot better they spray in a v and not just in a stream of water... m.o.t. here i come lol
The power comes from the sidelight power - if its not lighting either theres no power, or you have a ground problem (the ground problem would explain why the switch also does not work)
ah good one on the washers!
- red6n2
the earthing wire is brown right ?
Indeed or Brown/white in some circuits
