Aftermarket Stereo question?
Callum
Post by Callum »
Howdy,
I've just fitted my double din Alpine head unit into my 2007 Polo (after £60's worth of freaking harness adapters, arerial adapters and amplifiers!!), it appears to be on a perminent live, when I take the key out of the ignition I have to manually switch the stereo off?
Does this always happen, is there something I need to do to make it switch off with the key?
Thanks in advance
Callum
Karson3270
Re: Aftermarket Stereo question?
Post by Karson3270 »
Yeah, it's the same for all aftermarket stereos. Does your head unit have a detatchable face plate? If it does you only have to take that off and then you are sorted.
I don't know if you've noticed but, when you turn off your engine and take your key out, the ceiling lights don't come on unless you take your headunit out and then they come on.
Callum
Post by Callum »
Mine doesn't have a detachable face on it, and yeah I did notice the lights don't go on until you turn the stereo off and you can't lock the car either!
Thanks for the info.
Callum
blazeguarder
Post by blazeguarder »
Don't aftermarket head units have both a switched and a permanent live? If it does it should just require wiring into a suitable switched live point. Maybe these wires need swapping over or something? I seem to remember something about having to swap red and yellow wires to get aftermarket stereos working with the ignition... not sure how accurate that is though.
Gillen
Post by Gillen »
As said above, just switch the red and yellow wires ;)
Callum
Post by Callum »
Gillen wrote:As said above, just switch the red and yellow wires ;)
I already tried that, didn't make any difference apart from the 'lights on' buzzer didn't work when it was the wrong way round!
kc
Drives: an imaginary one... for now
Post by kc »
just take a switched live some somewhere
the cig lighter positive works!
take note though, theire are two, one switched for ignition, and one switched for illumination
so just tap into the ignition live!
hope this helps
Callum
Post by Callum »
Nice one, cheers chap.
I wasn't sure if there was just a straight forward mod, before I got cutting & splicing into wires!
Thanks for all the help
Callum
