Fitting of GTI Grill
md1
Post by md1 »
Hi, need some advice, on how to fit a gti grill that i have just won off ebay - is there a step by step guide that someone can post up please..
red6n2
Re: Fitting of GTI Grill
Post by red6n2 »
i think its like stupidly easy 3 clips in the bottom a few in the top then close the bonnet done
someone should be able to confirm
dub6n2
Post by dub6n2 »
ohh it's dead easy. if not already loose, un-clip the 3 clips on top of the grill using a flat head screw driver, pull up the grill and clip the new one down :wink:
md1
Post by md1 »
Thank you.....will do, hope is this easy!!
6N2 GTI 00
Post by 6N2 GTI 00 »
Its probably the easiest thing to change on the car.
Just be very careful when removing the old grille because the 4 clips at the top of the grille need to be opened and then pull the grill out carefully, if your heavy handed you could end up snapping the 3 slots at the bottom.
